16th December 2018, 05:07 PM
#41
Ok Guys, the rack system in place, this solar panel not going anyway regards Alex p.s. And Yes I made it myself,
The Following User Says Thank You to altech For This Useful Post:
mudski (21st December 2018)
16th December 2018 05:07 PM
17th December 2018, 09:12 PM
#42
Ok Guys, check battery this afternoon and is showing 13.7 because I set on the controller hours only at 2 hours per day, So I think I'm happy with that, not 14.4 as it was showing yesterday regards Alex
19th December 2018, 10:49 PM
#43
I was thinking of making one of these before I sold the Patrol
May still make one for the new ute
Proud BTrol Owner
The Following User Says Thank You to Yeti's Beast For This Useful Post:
GQtdauto (20th December 2018)
20th December 2018, 08:09 AM
#44
Yeti's Beast
Proud BTrol Owner
Looks good , whats that 2 panels of 200watt each regards Alex
18th March 2019, 05:43 PM
#45
Hi Guys, just upgraded from a PWM to MPPT solar controller as this will be better for my needs and finally fitted my second battery that located in my draw unit and now have the dc to dc controller runing to charge the second battery. all seem to be working great. oh happy days of free energy from the Sun, :-)
18th March 2019, 06:35 PM
#46
I hope you have been keeping that battery charged because more than likely it’s stuffed. See the competition sticker in the front !
That ended June 2016
Proud BTrol Owner
18th March 2019, 06:38 PM
#47
altech
No, they were 12v 180 watt
Proud BTrol Owner
19th March 2019, 07:16 AM
#48
Yeti's Beast
Proud BTrol Owner
all good on the second battery 13.4 V
19th March 2019, 07:27 AM
#49
Is that a wet cell battery? inside the cabin? Not a great idea. I had a calcium wet cell crap out and it filled the cabin with fumes and that means corrosion - yet to get a handle on the potential of what slow creeping damage I have to the electronics inside the car. Cleaned out @MudRunnerTD sinus's!!!!
The Following 2 Users Say Thank You to PeeBee For This Useful Post:
MudRunnerTD (19th March 2019), Yeti's Beast (19th March 2019)
19th March 2019, 08:50 AM
#50
Moderator
altech
Hi mate, good effort sorting all that out. I dont want to rain on your parade at all mate but a couple of comments for your consideration though. I think the cables coming off your Projector150 are very small and not big enough for a dual battery system beyond a trickle charge and i'd consider swapping them for something bigger. Also i note you have used domestic 240v 3core flex for your wiring. I have used this in a previous build thinking it was the go but it lacks flexibility and goes hard over time. It doesnt like vibration and lack efficient current flow on 12v. a fine multi strand will be far more flexible and provide much more efficient 12v Current flow. I would avoid using 240v anything on your car. It will probably get you years of service but maybe not.
Check out my Toy -->
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
PeeBee (19th March 2019), Yeti's Beast (19th March 2019)
