Results 21 to 30 of 44
Thread: Going Solar on the GU wagon
    191 Post(s)
    Awesome proven information Cuppa mate and keep trucking outback strong good man!
    My short term memory has been jogged thanks to your kind post of ‘Sikaflex 252’ being the hero to date for sure.
    A ‘Big4’ (Winnebago style camping) neighbour recently had drop down side tables “glued” on all over its smooth etched exterior by professionals with 252.
    Still does slightly worry me a bit as cool/clean rooms and ‘Sika’ was a past life gig of mine with customer needed time logged maintenance regimes an absolute must.
    Just not sure how Burk & Public (Googled) warranties explain long term harsh usage good man!
    86 Post(s)
    Mate of mine built his motor home body on the back of a 4wd Canter entirely of fibreglass sandwich panel. All glued with Sika, not a single mechanical fastener. Drove it overland to the uk via China, Mongolia, all the ‘Stan’s etc, then to Africa, & then back to Australia. 3 years full time on the road, taking the worst that could be thrown at it. Various repairs along
    the way to vehicle, but not a single repair needed to the motor home body.
    http://www.epicycles.com/Truck%20Blo...2010-01-01.htm
    2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, 240v, 3” Genie exhaust + dynotune, 2” lift, Lovells GVM upgrade, ROH Blaktrak steel wheels, Bridgestone D697’s, Redarc gauges/pillarpod, Hema HX-1, CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, Tyredog TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare)
    A Nomadic Life
    The Big Trip Blog
  4. The Following User Says Thank You to Cuppa For This Useful Post:
    MB (4th December 2018)
  5. #23
    191 Post(s)
    Absolutely truly awesome Rig Cuppa mate thanks again. Only meant in regards Sika and its full rooftop exposed 100kmph capabilities longterm and when exactly to schedule a reassessment over the years.
  6. #24
    Expert altech's Avatar
    Nov 2011
    Bittern, 3918, VIC
    Hi Guys week on now, battery fully charged, my ? is what volts should the battery be at as the charge controller is showing 14.4 Volts. I'm thinking it's overcharging regards Alex
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  7. #25
    84 Post(s)
    Crikey, that’s truly horrible to hear gents!
    Slightly off track but an old surfer mate and I as ‘P’ platers accidentally speared a following cars windscreen with his lightweight fiberglass board on a 100kmph freeway in our 20’s. Have never used ‘Octopus Straps’ ever again and thankfully she was tailing us passenger less as it penetrated through to near the head rest position, scary scary lucky stuff for all involved that day :-(
    What did you stick the board down with Bong glue.
    Ocky straps should never been used down see how ppl still use them
    As for the solar panel two Rola areo roof racks even 3 if you want
    and bolt panel on using correct brackets.
    Then there was louwnes at bathurst that wore someones wheel and tyre combo
    14.4 sounds max a smart charger should stop charging at max imo
  8. #26
    36 Post(s)
    14.4 is too high for float charge on a wet lead acid.
    13.5 is ideal, no more than 13.8. Floating any higher reduces the life of the Battery.
    Your system may not be floating for a few reasons but most likely two are;
    A cheap as shit Reg that doesn't have a float cycle
    or
    A parasitic load high enough to trick the Reg into thinking the Battery isn't charged yet.
    Either way... 14.4 isn't good (great for charging a low Battery, crap for maintaining a charged one).
  9. #27
    86 Post(s)
    14.4v is OK & tells you the charger is doing its job.
    14.4v is the voltage the charger should take the voltage up to on a wet or AGM type battery By only reading the voltage it is hard to know *how* full the battery is, but it will be at least 70% to 80% charged, possibly higher.
    The way it works is that in bulk charge mode the charger gives the battery as much current (amps) as it can. This raises the voltage up to 14.4v (some may go to 14.5 or even 14.6, but 14.4 is the most common). When the battery reaches 14.4v the charger changes from bulk mode to absorption mode. Here it reduces the current whilst maintaining the 14.4v for a set period of time (how long varies from one charger manufacturer to another). After this set period the manufacturers determine that is sufficient to now consider the battery ‘full’, at which point the charger will drop into Float mode, where it reduces the voltage & holds the battery at a lower voltage - usually between 13.3v to 13.8v. The battery if left connected to the charger& no loads applied can remain at this voltage indefinitely. If a load is applied (something is switched on) the voltage will drop & the charger will kick into its charging cycle again.
    Some of the fancier multi stage chargers have more than the three stages, but essentially they all work in much the same way.
    EDIT Just read ET’s reply so need to add to mine to save confusion. IF as ET surmises, your battery *is* fully charged & not dropping into float mode, it either is t working properly or is not a smart charger. If it has been at 14.4v for more than 4 hours you should disconnect it from the charger & in future monitor the battery charging to ensure it is not left on too long. If the battery is a wet type battery, & it has been held at 14.4v for too long there is a good chance it will have lost fluid & needs to be topped up with distilled water to ensure the lead plates are fully covered. If this is what has happened investing in a smart charger (3 stage or multi stage) would be a good idea.
    A Nomadic Life
    The Big Trip Blog
  10. The Following User Says Thank You to Cuppa For This Useful Post:
    the evil twin (15th December 2018)
  11. #28
    36 Post(s)
    Cuppa... maaaate... I agree with what you say except for one thing.
    He's had the sucker on a 200 watt panel for a week... if it isn't floating by now something is amiss and 14.4 all day long (obviously not at night) isn't doing the Battery any good . Less harm than going flat tho of course.
    I float 2 x N70 wets on my Chev Cab Chassis with a 25 watt panel (well, my ex-Chev) and that was with all the normal fruit and a Codan HF parasitic drain
    On the rare occasion I hook up my 100 blanket it would float in about 60 to 90 minutes
    @altech Uuummm, just had a thought, when are you checking the 14.4... first thing in the morning or end of day
  12. #29
    86 Post(s)
    Hi ET, I realised that when I saw your response, just after I posted mine. Have since added an edit to mine in the hope of avoiding confusion. Suspect it’s a cheap ‘dumb’ charger, although I did once have a supposed smart charger which obviously wasn’t, sold as being suitable for permanent long term connection to a motorcycle battery. Killed the battery stone dead, found the carcass bone dry after a couple of months.
    ANOTHER EDIT . If it’s the solar charger pictured earlier in the thread it should have a float mode, although mention of timer on its front case is a bit odd for a solar charger. Perhaps there is a parasitic drain & the reading is taken in the morning? Suggest battery be disconnected ( remove all connections except for charger, & then keep a regular check on battery voltage. If it reaches & remains at float voltage all is good. If there is a parasitic load (clock, radio on standby or whatever) you can then decide whether to disconnect it or not. If the voltage reading is fairly early in the morning, & you have a parasitic load using a bit of battery power overnight , AND the battery goes into float later in the day each day, then you don’t have anything to be concerned about.
    A Nomadic Life
    The Big Trip Blog
  13. The Following User Says Thank You to Cuppa For This Useful Post:
  14. #30
    36 Post(s)
    No worries Cobber... tired of Mangoes and Mub Crab yet?
