1st December 2018, 07:58 PM
Aircon not blowing on any settings
Need help. Aircon stopped blowing on any settings. Heater resistor looks to be ok. Help
1st December 2018 07:58 PM
1st December 2018, 10:51 PM
Check the fuse. If it is ok then the fan connector is easy to get to. Unplug it and measure the voltage across terminals. If there is voltage then check the fan connectors for continuity. It should only be a one or two of ohms of resistance.
The Following User Says Thank You to mudnut For This Useful Post:
PeeBee (1st December 2018)
