Results 1 to 2 of 2
Thread: Aircon not blowing on any settings
    Jul 2013
    Need help. Aircon stopped blowing on any settings. Heater resistor looks to be ok. Help
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Check the fuse. If it is ok then the fan connector is easy to get to. Unplug it and measure the voltage across terminals. If there is voltage then check the fan connectors for continuity. It should only be a one or two of ohms of resistance.
  4. The Following User Says Thank You to mudnut For This Useful Post:
    PeeBee (1st December 2018)
