Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: RB30 Compression for turboing
    Jul 2018
    SE Vic
    Howdy, Jay here. Im getting different answers about if it's worth doing due to compression. Ive been told by 1 mechanic that i need to change comp otherwise wont get much boost. Cost 20 k. 2nd opinion from performance workshop is that the RB30 has alright comp to just bolt on a turbo and run up to 10psi. I need to know if I need to rebuild engine? It's in a manual Gq wagon. 91 model. Any advice would be appreciated,
    Thanks .
    80 Post(s)
    20k! He's dreamin'.
    Jul 2018
    SE Vic
    What do i do then?
    80 Post(s)
    If you want to run really high boost then you would look at doing something. Have heard that some use thicker head gaskets as quick fix. I will talk to an expert tomorrow, get his opinion, and get back to you.
    80 Post(s)
    Has it already been converted to fuel injection?
    Jul 2018
    SE Vic
    No, still carby.
  8. #7
    80 Post(s)
    I talked to the local Dyno guy. He builds racing engines and is very good at it. He said unless you are running a high boost, high performance engine, then you should be able to get the thing built for around 1/3 to 1/2 the price.
    For a low boost engine, all that should be needed is low comp turbo pistons (concave crown) and a turbo compatible camshaft. As the RB30 bottom end is strong, then the original rods should be ok. Using thicker head gaskets is not a good option.
    RB30 EFI conversion http://www.nissanpatrol.com.au/forum...EFI-Conversion
    Or use a Weber carby suitable for boost. The original carby is unsuitable for boost as it is a two stage vacuum dependant unit.
  9. #8
    Jul 2018
    SE Vic
    Would i be better doing a Barra conversion as ive heard it can be done for around 6-7 k. Its going to take a while for me to get cash up for anything. I just feel like RB30 needs a little more power for off road, it fairly sluggish on road already. . Thanks again.
  10. #9
    80 Post(s)
    I get 80 kw rear wheel with a set of headers, snorkel, carby rebuild and the heater grid from under the carby removed. I also block the pre-heat flap vacuum hose during the warmer months.
    I am very happy after the guy dyno tuned it, as it gets 13.5-14 litres per 100ks highway driving.
    http://www.nissanpatrol.com.au/forum...-Helpful-Hints
    What size tyres are you running.
  11. #10
    Jul 2018
    SE Vic
    31" at moment but going to 33".
    When i put new timing belt on i noticed that the previous owner had set it 1 tooth different from stock. Ive had it put back to stock.
    I haven't been off road in it yet,just feels underpowered. I had to put another oil pump, dizzy and alternater on it when i bought it. . I'll take the heating grill off,has headers already. Thanks for your help. J
