16th November 2018, 07:06 AM
Headlight and ignition alarms/buzzer
I see a number of members have wanted this buzzer turned off
I’m different I want it on and it has recently stopped working.
My questions are;
1. How can I determine why it has stopped working, and
2. How do I get it working again
16th November 2018 07:06 AM
16th November 2018, 11:24 AM
Faulty door switch did this to a previous Magna sedan I had. I can’t remember exactly but I think the door thought is was closed even though it was open.
Easy test turn your roof lights onto door setting and open and close each doo and if the light works correctly then it’s not a fault switch if the light doesn’t come on then the door is opened then the switch isn’t good.
Worth a shot and that’s all I can think of.
17th November 2018, 04:32 AM
Fireblade
Thanks FIREBLADE
17th November 2018, 03:03 PM
Curious did it end up being the door switch?
10th February 2019, 12:02 PM
Fireblade
Sorry for late reply.
No not the switch. Still haven’t been able rectify the problem.
11th February 2019, 02:42 AM
it might not be that great but jaycar were selling kits to add one to older cars without it, I know not as good as the factory one but.
i'm not sure how its wired but it could be a number of things including the buzzer itself, broken wire, where is it fused ?
12th November 2019, 11:04 AM
garett
Thanks. Where is it fuzed? Not really sure - it’s the original but not sure where fuzed. I have not looked and not with the car at moment
12th November 2019, 07:27 PM
Made one for the GQ (they don't come standard)
Easy peasy = light circuit (headlight) power through ordinary relay T30 with piezo buzzer connected T87a and earth, ignition accessory power T86 , earth T85.
When ign or acc is on, relay activates and diverts light circuit power to T87 (empty). When ign/acc is off, T30 light power goes to T87a (buzzer)
