IIRC ABS is standard on all models after 2006... prior to that it was dependant on options/model.
You can't miss all the extra plumbing on the firewall for the ABS system (if equipped)
If you are going for a ZD30 Di then I would recommend series 3 or 4... or try for that bit extra cash and get a CRD (series 5 onwards)
