Results 1 to 10 of 10
Thread: No cat and no muffler defect?
    Advanced Salim's Avatar
    Nov 2018
    Villawood NSW
    Hi guys,
    I've just purchased an 08 Patrol and have seen a nice sounding exhaust kit (which is under $400) but it's got no cat and no muffler.
    My question is, is having no catalytic converter a defect in NSW?
    I've heard some instances of people being heavily fined for not having a cat on their exhaust system but not sure if that was in NSW or not.
    Thanks in advance for the help
    194 Post(s)
    I would think, regardless of which state you are in, if you remove a pollution device, as fitted originally from the factory, the vehicle would be subject to infringement if you get caught. Probably more likely in NSW due to the yearly inspections also.
  4. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    mudski (8th November 2018), Salim (7th November 2018)
    Huge no no, and a huge fine to go with it, grab a high flow cat and keep it legal
    Thats what I reckon you should do. and get a egt bung weld on as well
  6. The Following User Says Thank You to threedogs For This Useful Post:
  7. #4
    Put a Hi-flow Cat on for sure IMHO... not worth the risk to not have one
  8. The Following User Says Thank You to the evil twin For This Useful Post:
  9. #5
    175 Post(s)
    No muffler ? Ok if within the dB level , and if your neighbour likes you.
    If your car rolled off the ship onto Aussie soil with a cat, you then shall have a cat.
  10. The Following User Says Thank You to Hodge For This Useful Post:
  11. #6
    Nov 2018
    Villawood NSW
    Thanks for the replies guys that's what I expected.
    Threedogs what does the EGT bung do?
  12. #7
    "EGT Bung"... adapter for an Exhaust Gas Temp probe... much better to do before the exhaust goes in rather than after
  13. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Salim (7th November 2018), threedogs (7th November 2018)
  14. #8
    Most high flow cats will probable have one but check when you buy it.
    easy to fit an EGT gauge.
  15. The Following User Says Thank You to threedogs For This Useful Post:
  16. #9
    Nov 2018
    Villawood NSW
    I'll definitely look into it once I can afford to fork out cash on upgrades.
    Thanks guys.
  17. #10
    462 Post(s)
    A cat will need to be on there for sure. As stated 100%. In Vic, even if its under the db limit, you still are required to have a muffler of some sort. So a small hotdog muffler in there will keep the fuzz off your tail. I went from no muffler to a hotdog and there was little difference in sound.
  18. The Following User Says Thank You to mudski For This Useful Post:
    Woof (8th November 2018)
