Results 1 to 5 of 5
Thread: TD 42 trouble starting
    Apr 2016
    Question TD 42 trouble starting
    Hi All,
    I've got a 1994 with a recently rebuilt engine.
    with around 6000 ks on the new engine
    Just recently I started having issues when starting.
    When cold the engine starts more or less as normal. Turn on the ignition, lights on the dash come on including glow plugs lights go out turn the key engine starts on the first or second go.
    if I do a few short trips then it struggles to start. led me to thinking Alternator but the charge rate from the alternator is good.
    I've also checked the battery and the glow plugs both are good
    Once started it runs normally so I don't think fuel starvation is an issue,
    leaving the starter motor.
    seems to crank normally
    Any ideas?
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    37 Post(s)
    Mine is the same and the mechanic reckons starter
    342 Post(s)
    When it doesn't want to start does the engine turnover or nothing at all?
    sunshinecoast
    perhaps air in the fuel line ? when you think it might have trouble starting , first try pumping the fuel primer before trying to start the car .
    May 2016
    4 Post(s)
    job one check the compression .. have had a few that run out of compression and only new reco....
