Results 1 to 4 of 4
Thread: Injection Systems
    Nov 2018
    Sydney
    Injection Systems
    probably a dumb question for those in the know but I am wondering if the early GU direct injection engines are "common Rail" or is it just after a certain year?
    I believe that common rail gives better power but at the expense of economy, and I would rather have the latter.
    thanks in advance.
    461 Post(s)
    Quote Originally Posted by Orcrist View Post
    thanks in advance.
    Different setups. Direct injection is as it states. You have the injector pump, injector lines then injectors. Common rail, have a fuel rail, in between the injector pump and injectors. Im not up to speed with these but I think the fuel rail is what controls the fuel delivery pressures to the injectors, where on a Di, the injector pump does all this. The injector pump on the CRDs pump the fuel through to the rail and injectors at a much higher pressure than a direct injection motor, hence giving a slightly better power delivery and better fuel economy.
    175 Post(s)
    Direct injection is where the pump has 4 direct individual outputs to each corresponding injector ...
    Common rail pump has only one output.
    It pumps fuel into a common chamber ( kind of like a tank on a air compressor) " rail" and then from there , there are 4 individual lines all at rail pressure to injectors. Injectors are then controlled and cracked electronically.
    Crd pumps are way simpler and therefore a lot cheaper too than Di pumps.
    Nov 2018
    Sydney
    Great info, thanks for that mudski and Hodge.
