Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: TD42 differences
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Quote Originally Posted by jjjag View Post
    what do you make of this engine 2002 Attachment 76848
    engine numbe td42
    TD42036164T
    Mine is TD42-0046xxT in a 2001 GUII and is from a '96 Y60 Safari. Engine was imported from Japan.
    John
  2. The Following User Says Thank You to jff45 For This Useful Post:
    GQtdauto (13th November 2018)
    engine numbe td42
    TD42036164T
    It is a factory turbo TD42t
  5. #13
    Jun 2018
    basically that im trying to see if the number sequence started again y60 to y61 or gu / gq
    i found a few others for sale though i havent i seen in person
  6. #14
    Jun 2018
    did these come out with turbo
  7. #15
    581 Post(s)
    Yep yours would've been turbo from factory.
    The engine number ending with T would mean that.
    Some factory turbos I think also had an A and Winnie's new engine ends with E as factory turbo replacement engine.
  8. #16
    Jun 2018
    does anyone have a na with 55mm front crank nut
    or have td42 factory turbo with a low number like the one above
  9. #17
    Jun 2018
    question being mines td42 0956xx but seemingly has all factory turbo characteristics
    ive seen ai think a couple without the t or e but were t engines
    sorry i am going around in circles
  10. #18
    What are the factory turbo characteristics you think it has?
  11. #19
    Jun 2018
    thanks
    55 crank nut ( is the small nut the same thread)41mm
    1" block drain
    thermo water feed
    11mm compensated pump
    im sure all could and can be retrofitted
  12. #20
    Morayfield, QLD
    The factory turbo block will have a M10 x 1.5 turbo oil feed just below 1 & 2 exhaust with a 3/4 BSPT turbo oil drain in the block.
    It will also have a M12 x 1.5 turbo coolant feed just in front of the oil pressure regulator.
    John
