Results 1 to 6 of 6
Thread: Broken bolt and stud removal.
    G'day all. This short youtube clip shows some easy techniques to remove broken bolts and studs without damaging the thread. I hope you find it helpful.
    https://www.youtube.com/watch?v=dJfkCj3FWBs&t=465s
  2. The Following 3 Users Say Thank You to mudnut For This Useful Post:
    BillsGU (23rd October 2018), GQtdauto (23rd October 2018), jack (23rd October 2018)
    Okay, brain trust. I have two seized bolts in the thermostat housing of our EB falcon. They're 8mm thread with 13mm heads. They hold the aluminium case to an aluminium block which is bolted to the engine block. The gasket between the thermostat housing is weeping quite badly, so something needs to be done, before it causes bad issues.
    Do I :
    a) put some silver seal in the coolant and wing it?
    b) break the bolts and repair the threads as in the first post?
    c) alternately apply heat and cold to the heads of the bolts to try and shock them free before breaking them any way?
    d) take up drinking and forget the universe ever existed?
    192 Post(s)
    Option D sounds pretty good . . .
  6. The Following User Says Thank You to Rossco For This Useful Post:
    mudnut (16th December 2018)
  7. #4
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Option "D" for sure it's worked for me and I'm gunna get to that one fricken rounded hex bolt holding the tow bar on when I run out of beer .
  8. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    mudnut (16th December 2018), Rossco (16th December 2018)
  9. #5
    175 Post(s)
    Option B or C ... Do it right , I say.
    Otherwise it'll bite you in the future .
    TD42s have a long bolt through the thermo housing , and more often then not , makes people hate life I've heard. Mine was ok thank f**k.
  10. The Following User Says Thank You to Hodge For This Useful Post:
  11. #6
    After seriously considering d), I used an LPG blow torch to heat up a 3/4" piece of bar until it was just below red hot. I then used multi grips, to hold the end of the bar onto the heads of the bolts for about 30 seconds each.
    After letting the bolts cool properly, I tried undoing them using a heftier ratchet. I got both to move a little, so here's hoping they won't break when I get a new O ring and try to replace it.
    ( I replaced the bloody O ring only a few months ago, and I still thought it needed a new gasket. Maybe too much of answer d) in my youth).
  12. The Following User Says Thank You to mudnut For This Useful Post:
    GQtdauto (16th December 2018)
