Results 1 to 3 of 3
Thread: how to service these grease points. image provided
    Sep 2018
    queensland
    hi
    i recently got some swaybar links and they have a grease point ive not seen before.
    i thought i could un thread them and put in a m6 grease nipple but these arent even threaded they are a push in fitting.
    i pulled one out and its diameter is so small id have to drill out the part and tap it for a m6 grease nipple.
    other thought is to pull out the fitting and use a grease needle but i dont think itll work, probably make a mess as the grease wont be forced into the rose joint.
    my question is, is there a tool designed to service this style of grease fitting?
    460 Post(s)
    I think you use one of these.
    https://www.stm.net.au/grease-equipm...tor-needle-tip
    I have seen those before but never really thought how to get grease into them.
    More of them here....
    https://www.stm.net.au/grease-equipment/15/1/4/
    Sep 2018
    queensland
    yeh that might work, may even have to pull the cap out to do it
