Results 1 to 4 of 4
Thread: TB45e coil replacement
    Mar 2017
    Hi Just wondering how hard it would be to replace coil in my TB45 engine, I think I cold do it or should I get it done by a mechanic they quoted me $300.
    Cheers Grant Murray
    Legendary
    193 Post(s)
    Depends on how handy you are , what tools you have and what you value your time at? I can do mine in about 60 mins a side after setting up for it and finding all the gear. Its not hard, just need to approach it from a safety perspective and you should be ok. I use a combination of coil compresser and jacking the vehicle as I don't have a hoist. I have had coils swapped over in the past and cost was between $200 and $250 from memory.
    Sep 2018
    queensland
    3 Post(s)
    my method was 2 ratchet straps on each coil and then jack up from the chassis and pull the coil out.
    i would not recommend this at all though highly dangerous
    to undo the straps i used a long screw driver so my fingers were as far from danger as i could be, while also shielding my body.
    do as i say and not as i do..
    i didn't wanna pay for tools that i could only see myself use once.
    Mar 2017
    sorry guys I meant the coil in the distributor as it has a internal coil
    Cheers Grant Murray
