Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Coolant issue
    465 Post(s)
    Quote Originally Posted by tassie wombat View Post
    Judt had a look on Ebay and the only thing I could find in regards to a coolant bleeder were bleeder screws ?
    This is what I bought.
    https://www.ebay.com.au/itm/Auto-Coo...G8D:rk:44:pf:0
    Can't remember if this is what I paid but it works a treat.
    MB (14th October 2018)
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I have one of these also. Good unit
  5. The Following 2 Users Say Thank You to 4bye4 For This Useful Post:
    MB (14th October 2018), mudski (14th October 2018)
  6. #13
    Expert tassie wombat's Avatar
    orielton,tasmania
    Thanks for that 🍻
  7. The Following User Says Thank You to tassie wombat For This Useful Post:
  8. #14
    473 Post(s)
    FFS, please do think of our children!
    Pre-Loved Coke bottles & Gaffer/a tape, are truly carbon neutral off a 4.2TD and or 6.5Chev plant ;-) !
  9. #15
    175 Post(s)
    The yellow spill free funnel kit I've used for a long time in conjunction with uphill theory on my TD42 . Works great.
    Bit easier on mine as it's got the self bleeding 2 side tank setup. So it gets rid of small remnants of air on its own after initial major bubble bleed.
    orielton,tasmania
    I've never had any trouble before until now, I tried again yesterday arvo, put front on ramps, and started with funnel on radiator then moved it to the Recovery bottle, didn't see any huge amounts of bubbles come out ?
  11. #17
    465 Post(s)
    your supposed to bleed your setup from the pressure tank on the lhs of the engine bay. you need to bleed the entire system right up to there. Its different for the earlier Patrols that dont have this tank.
  12. #18
    orielton,tasmania
    I've had the funnel on both the radiator and the expansion tank
  13. #19
    Easier and cheaper than the ebay one, if you have a spare radiator cap. Just remember to disconnect the over flow hose off at the over flow bottle Lift it up and tape it to the burping bottle. This is so the excess water doesn't over fill the overflow bottle. I use the hose to drain the excess into a container after the burping is done.
    I used a door stop, bottle, hose clamp, piece of 1/2 inch pipe, a rubber washer and the old cap. Simples.
  14. The Following User Says Thank You to mudnut For This Useful Post:
    PeeBee (30th October 2018)
  15. #20
    orielton,tasmania
    Bit of an Update- looks like whatever air that was trapped ,is now gone,temp gauge is now fairly stable and sits between 75.c and 80.c with the new fan and hub.
  16. The Following 2 Users Say Thank You to tassie wombat For This Useful Post:
    Cuppa (31st October 2018), MB (29th October 2018)
