Results 1 to 10 of 10
Thread: What should I sell these parts for?
    201 Post(s)
    Hey fellas,
    Did a shed cleanout this arvo and needing to move these parts on to help fund the new engine. Just wondering what prices I should put on them? Prices below are just what I have guessed basically? Tell me if I'm dreaming or if I should ask for more?
    Complete front GQ diff housing, no centre or free wheeling hubs $50
    Rear GQ diff housing no centre $50
    GQ EFI twin piston calipers with rotors, have pads but will need replacing. $250
    Rear GQ calipers with good rotors and pads $100
    Rear GQ axles left and right $100 for the pair
    GQ CVs long and short $100 for the pair
    Standard GQ tie rod $30
    Standard lower control arms x5 (wrecked bushes) $25 each
    Standard GQ upper control arms with wrecked bushes x3 $20 each
    Standard GU series IV front and rear panhards with the large rose bush $30 each
    GU rear diff solid brake lines $20
    Harris hard case diff protector $100
    193 Post(s)
    Winnie, no idea on the prices but will take the front CV's long and short. Is the Harris hard case for the front or rear? If front I will take that as well
    201 Post(s)
    Hey Phil, the diff protector is for the front diff. I will send you some pics tomorrow.
    193 Post(s)
    Good enough from you, pics will help me to ensure i dont do another sump piercing activity on the chev. I will see if I can find a photo on the net. I already have a protector but had to modify it and not all that happy with it.
    OK, found a photo, looks fine. Let me know.
    22 Post(s)
    All the stock control arms zre throw away. I could barely give that stuff away.
    I would have gone 100 each on cv's
    I'd cut all the mounts off and clean up the diffs and try and sell the to hilux or Jeep Cherokee owners for a conversion.
    96 GQ coil/Cab
    08 G6eT
  7. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Winnie (10th October 2018)
    201 Post(s)
    Thanks Benny. Good idea about marketing to the conversion chaps.
    193 Post(s)
    If you do this, you immediately cut your market opportunity - think about this. If someone is doing a conversion they are aware and no doubt primed to do the removal of brackets, which would be a simple job. Priced to sell anyone in the market whether its for direct swap or conversion would be prepared to take the housings as they are I believe.
  10. #8
    Oct 2018
    PM me please
  11. #9
    22 Post(s)
    What, cut it further than selling a GQ diff without centres, CV's or Hubs? In this day and age most people aren't going to know they need untill they're told.
    96 GQ coil/Cab
    08 G6eT
  12. #10
    201 Post(s)
    Quote Originally Posted by pmip View Post
    PM me please
    What for? Who are you?
