Results 1 to 10 of 18
Thread: TD42T (i maybe) into GQ - Winnie
    581 Post(s)
    Gents, just trying to work out what else Winnie would need if he bought a TD42T or Ti block to put into his GQ.
    Yes I did it but have a memory like a fish!!!
    1. Water pump I think is same but the cover for the injector pump gear on timing case is different.
    2. Block off Vac pump on timing case
    3. Mount for the power steering pump
    4. Tacho sensor spacer if TI
    5. Rear main seal
    6. Flywheel
    7. New lines for turbo, oil feed and drain.
    8. Alternator oil feed and drain (I think I had to replace one of them from the GQ set up)
    9. Exhaust manifold studs, may as well.
    10. Engine mounts (just for Winnies situation)
    11. Gaskets, glue, etc etc
  2. The Following User Says Thank You to AB For This Useful Post:
    Winnie (8th October 2018)
    22 Post(s)
    You'll need lifters as they're smaller in a silver top.
    I have a bare T block, . I have no vac pump though
    Just buy a motor that has good compression and send it
    96 GQ coil/Cab
    08 G6eT
    Sorry just to clarify that the motor we are looking at is a complete long motor.
    22 Post(s)
    Complete as in manifolds pump etc,
    96 GQ coil/Cab
    08 G6eT
    Need to double check with them but assuming no bolt ons or manifolds.
    Dec 2012
    Work
    I put a TI motor in mine,
    Removed and blocked the EGR with a kit from performance 4x4 Queensland
    Drivers engine mount is different if using the TI pump
    Had to use GQ oil pressure switch
    I’ve fitted a GQ tacho sensor with a spacer (GQ sensor is longer)
    Used GQ loom, had the GU loom to steal plugs if I needed
    I’m using the vacuum pump on the timing cover and a GU alternator
    My motor came with the turbo flywheel
    Everything else was bolt up
    Just another Blue over Silver GQ with another TD conversion
  9. The Following 3 Users Say Thank You to Reddave For This Useful Post:
    MudRunnerTD (10th October 2018), PeeBee (8th October 2018), Winnie (8th October 2018)
  10. #7
    581 Post(s)
    Thanks gents, we are just looking for something for Winnie and if it goes ahead want to make sure we have everything sorted for a communal weekend build/install.
  11. The Following 6 Users Say Thank You to AB For This Useful Post:
    Hodge (9th October 2018), neet_wagon (11th October 2018), PeeBee (9th October 2018), rusty_nail (9th October 2018), Stropp (18th October 2018), Winnie (9th October 2018)
  12. #8
    Yeah pretty much just wanting to get a grip on what little things will pop up. Would love to be able to install and start up all in a weekend.
  13. The Following 4 Users Say Thank You to Winnie For This Useful Post:
  14. #9
    Why not throw in one of those bullet proof 3.0L di motors. I've heard good things about them
    On a serious note if I'm available I'm more than happy to come help out.
  15. The Following User Says Thank You to rusty_nail For This Useful Post:
    AB (10th October 2018)
  16. #10
    8 have my old water pump your welcome too.
