Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: TD42T (i maybe) into GQ - Winnie
    Would be great to get the flywheel with the motor and the PS bracket would be a winner too. Id think you could negotiate that into the deal
    Winnie (10th October 2018)
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Think you should just put in a TB4.2, I know of a good motor going for cheap in Sydney, ya just need 2 get the spark plug out
  5. #13
    Are we going to be able to use my clutch? Mine is fairly new and I would like to use it in the new engine but have read some conflicting info on the internet.
  6. #14
    581 Post(s)
    Yep the spline is same so will be fine.
  7. #15
    I have read that the bolt pattern is different. Some people say that you can use a GQ clutch on the GU motor but not a GU clutch on a GQ motor.
  8. #16
    581 Post(s)
    Yeah ok mine fitted perfect with no modifications.
  9. #17
    Okay awesome, good news cheers mate.
  10. #18
    The sandwich plate on the turbo motor is different, it has a bigger hole for the bigger crank.
    I can either buy a new one or grind out the hole to the larger size.
    Does anybody know the measurement for the hole to fit the bigger crank?
