Results 1 to 2 of 2
Thread: Need help removing dump pipe from ZD30
    Jan 2014
    Bathurst NSW
    Im wanting to install a EGT gauge in the patrol but first Im removing the dump pipe to install the fitting. Gotta say..that heat shield cam off in 30 sec and Ive never done one before...lol I just thought as it came away what all the fuss was about..lol, maybe putting it back on might be a different story..Anyways Ive got the 3 top nuts off at the turbo and the 3 nuts at the bottom of the dump pipe and now my question is what best method to remove the dump pipe itself, still seems to be in pretty solid. Ive googles and searched but cant find anything other than removing the heat shield as the biggest problem....help please.
    __________________
    Had a 1999 GU ST Patrol 4.5L Auto on Dual Fuel ...now have a 2003 GU ST ZD30TD Auto.
    Jan 2014
    Bathurst NSW
    Got it worked out guys, shes off the vehicle, saw the other bolt on the inside of the engine block. So for further information to others 7 bolts all up, 3 up top near turbo, 3 down bottom at where dump pipe joins exhaust and 1 more bolt between cat and engine.
  4. The Following 3 Users Say Thank You to tallman For This Useful Post:
    jack (6th October 2018), PeeBee (6th October 2018), rusty_nail (7th October 2018)
