Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Standard height? What is it?
    Advanced
    Apr 2011
    Hi guys, I have recently bought a patrol and have intentions of raising it. What I was wondering was if anyone knew what their standard height is so I can ascertain if it has been raised at all in the past and how much higher I might want to go? Does anyone knwo what height it should be from the factory and where it was measured from?
    Cheers,
    Yowie
    Feb 2011
    Shed
    45 Post(s)
    I think they measure from centre of wheel/hub to the wheel arch, im not sure wots standard tho what model is it mate?
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Usually measured from the bottom edge of the rim (for factory rims) to the metal top edge of the quarter panel flare (not the plastic).
    Not sure of GU original height, but "reasonably" sure the front of the GQ measured 762mm stock standard as detailed above.
    Advanced
    Apr 2011
    Broken Hill - Merbein - Pooncarie
    The measurement on the Front of my GQ is Centre of hub to wheel Arch 600mm
    and bottom edge of Rim to wheel Arch 800mm, I have Sunraysia Rims and 2" Lift fitted
  6. #5
    Advanced
    Apr 2011
    Cheers guys,
    growlers I have a 1993 tb42 gq if that helps at all.
  7. #6
    Advanced
    Apr 2011
    Hi bigrig, you are absolutely spot on for my rig! It is bang on 762mm. It must have had the suspension done at some time. in fact it is on monroe shocks but have no idea of age. Is there any way to tell?
  8. #7
    Oct 2010
    Quote Originally Posted by YalwalYowie View Post
    Have you checked in with the logbook? I'm one of those people who keep the receipts of work done so I know dates, costs etc. You might have been lucky enough to score the rig from someone who does the same.
    Other than that, I'm sure they'd be stamped somehow to tell production date, but would not show the actual installation date (could have been in storage/on the shelf for months).
  9. #8
    Advanced
    Apr 2011
    Cheers Bigrig, unfortunately I do not have a log book with the vehicle. I bought it having had a good check over and knowing it is free from rust. It has over 300,000 on the clock so I am aware that there are going to be some issues, but generally it is a good clean truck and a good solid base for building into something really nice... I hope so anyway. All I need now is time and money!
  10. #9
    Oct 2010
    Good stuff mate - look forward to the build thread!!
  11. #10
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    my gq with 10r tyres is eye level across the roof, if that helps. I'm 6 feet tall :-)
