Results 1 to 10 of 10
Thread: Another turbo thread
    Beginner Dads GQ's Avatar
    Sep 2018
    Hello people.
    Yes I know this has been touched on 1,238,002 times but who doesn't like talking about turbos.
    So my GQ has some high mileage. Like 500,000 kms high.
    tb42e engine... I want to turbo it but not too confident in the motor coping. So I am considering a rebuild before turbo charging.
    Does this seem sensible or unnecessary?
    Also it has extractors, will they get removed to install turbo?
    As it is vehicle with alot of sentimental value I would like to keep it as close to how I got it and would actually consider not turboing it if it required removing something that my Dad put on...
    I guess if that was the case I would still consider a rebuild and upgrade cams, whatever power upgrades you can go without turbo..
    What are my options?
  2. The Following User Says Thank You to Dads GQ For This Useful Post:
    MB TD42 (1st October 2018)
    581 Post(s)
    Not a lot of tb42 GQ owners floating around here unfortunately mate, hopefully someone can help out.
  5. The Following User Says Thank You to AB For This Useful Post:
    Dads GQ (4th October 2018)
  6. #3
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    Gday mate I have one the same...NA but i only got 250k on mine...
    best bet...get your head and compression checked...make sure it doesnt burn oil and yes you will be swapping your extracors out for a turbo manifold and dump pipe that will have to be grafted onto an exhaust if your keeping it.
    Thats as far as I have gotten...best to get the donk checked out by a pro before boosting...Boyles law come into effect when you add pressure to a cylinder...P1T1V1...basically your boom chamber will get hotter...your intake will get hotter and your zorst will get hotter so sort your cooling out as well. A good head and Radiator with new tweeked water pump should give you good results.
    I am no expert and asking one would be the go. Actually ask heaps of em the same questions. Hopefully you gt the same answers.
    best of luck...
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
  7. The Following 2 Users Say Thank You to MB TD42 For This Useful Post:
    AB (1st October 2018), Dads GQ (4th October 2018)
  8. #4
    Sep 2018
    Quote Originally Posted by MB TD42 View Post
    best of luck...
    Cheers mate.
    In terms of cooling is there aftermarket options?
  9. #5
    Expert billyj's Avatar
    gordon
    do a compression test mate, if the numbers come up good and it doesnt use any oil id have no issue bolting a turbo on, i put one on my old tb42e gq at 390,xxx kms and sold it 3 years later at 460k with no engine issues. that was running 10psi without intercooler. still wish i hadnt sold that rig was alot of fun to drive
    gone to the dark side 2017 vdj 79 dc
  10. #6
    Sep 2018
    Awesome..
    What turbo did u use?
    Can you give me an idea of what I need to do and the costs involved please?
    Bloke at work is all nah nah don't turbo it waste of money just chuck an ls3 In it lol.
    Sounds great but $$$
  11. #7
    22 Post(s)
    Use a garrett 3576 or 3582 or non garrett equivalent.
    You could buy secondhand of an xr6 turbo, but you take a risk doing that
    The biggest risk for a conversion is the shit quality workmanship from the conversion mobs.
    Some stuff is pretty rough
    96 GQ coil/Cab
    08 G6eT
  12. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Dads GQ (6th October 2018)
  13. #8
    Sep 2018
    Cheers mate. Hearing the xr6 garrets are the go!
  14. #9
    gordon
    i had a much smaller turbo came in a kit from axt turbos, i set mine up to make boost more or less from idle yer it sacrificed a little power up top but had tons of torque down low more like a diesel and was very useable while still being quick enough to leave my dc cruiser for dead
  15. The Following User Says Thank You to billyj For This Useful Post:
    Dads GQ (7th October 2018)
  16. #10
    Sep 2018
    Yeah nice. I would be chasing that power down low. Bit of giddy up straight of the mark.
