Results 1 to 10 of 12
Thread: Help - Water leaking 4.5 rear of firewall
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys, my old girl is leaking water bad near firewall heater hoses, but can't see where it coming from due to the 4.5 engine bay . water is streaming out under engine power, My son doesn't think its the small heater hoses . look on pdf gu manual, no diagrams whats their. any ideas or photo's guys what i'm looking for regards Alex
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
    Is it a welch plug ?
    Nov 2011
    Rupanyup, 3388, VIC
    Hi 3dogs ,can't see due to firewall , is there a welch plug at the back off block near firewall regards Alex
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys, Maybe found leak at back of block near fire wall, it looks like a Welsh plug as can see from video. Maybe ????
  6. The Following User Says Thank You to altech For This Useful Post:
    mudnut (28th October 2018)
    194 Post(s)
    FMD. Thats a steady flow
    194 Post(s)
    What's the story? Welch plug, garden hose left on under bonnet, fire suppression device????? Hope its not a major for you to resolve.
    altech (29th October 2018)
  10. #7
    462 Post(s)
    The water is not coloured like coolant should be. I take it you just top it up with plain old water? Anyhow a leak that bad looks like a welch plug to me.
  12. #8
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Mudski, Coolant gone long ago. I had the water hose topping up the radiatar and it was coming out the hole. Can you tell me is there ment to be a welsh plug at the end off block . Can't find any diagrams on this area. cheers Alex
  13. #9
    462 Post(s)
    Not sure myself mate but I assume there would be. Use a little mirror and check. Is it from the block or head you think?
  14. The Following User Says Thank You to mudski For This Useful Post:
  15. #10
    462 Post(s)
  16. The Following User Says Thank You to mudski For This Useful Post:
