Results 1 to 5 of 5
Thread: Valve stem seals leaking
    Expert First Pooy's Avatar
    Mar 2018
    Is there a common problem with Td42 valve stem seals leaking?
    192 Post(s)
    Not usually, what are the symptoms?
    Mar 2018
    Cylinder 6 vavle stem was leaking and I was eventually going to fix it but on the weekend number 1 cylinder valve stem seal started leaking
    22 Post(s)
    Quote Originally Posted by First Pooy View Post
    No usual as a regular failure/weakness. But valve stem seals can start failing with age on any motor regardless of brand.
    Poor service history can easily contribute to leaking seals on a TD, also a td with an EGR.
    96 GQ coil/Cab
    08 G6eT
    Mar 2018
    The motor was rebuilt about 7000 km ago with a new head so I don't know why it would be leaking now but I thought my it was a bad head build or cheap seals were used
