17th September 2018, 08:01 PM
Valve stem seals leaking
Is there a common problem with Td42 valve stem seals leaking?
17th September 2018 08:01 PM
17th September 2018, 09:08 PM
Not usually, what are the symptoms?
17th September 2018, 09:24 PM
Cylinder 6 vavle stem was leaking and I was eventually going to fix it but on the weekend number 1 cylinder valve stem seal started leaking
18th September 2018, 07:20 AM
Smart like tractor
First Pooy
No usual as a regular failure/weakness. But valve stem seals can start failing with age on any motor regardless of brand.
Poor service history can easily contribute to leaking seals on a TD, also a td with an EGR.
96 GQ coil/Cab
08 G6eT
18th September 2018, 09:33 PM
The motor was rebuilt about 7000 km ago with a new head so I don't know why it would be leaking now but I thought my it was a bad head build or cheap seals were used
