Results 1 to 10 of 15
Thread: Life Hacks 101
    Life Hacks 101
    New thread. Life hacks. Bring it!!
    Cable tie the milk crate to the front wheel when working on the patrol so it doesnt slide out
  2. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB TD42 (26th June 2020), Stropp (3rd April 2021)
    201 Post(s)
    Cable ties on the bread crate is a good one!
  5. The Following 7 Users Say Thank You to Winnie For This Useful Post:
    Maxhead (19th June 2020), MB TD42 (26th June 2020), Plasnart (5th June 2023), Rossco (13th September 2018), rusty_nail (13th September 2018), Stropp (3rd April 2021), TPC (25th July 2020)
  6. #3
    461 Post(s)
    I just use a rubber mat under the milk crate. Like the slow cooker idea though.
  7. #4
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Worse idea ever, I'd wake up during the night smelling something nice..... go have a feed, go back 2 bed then wake up and have 2 cook again!
    And end up fatter than I am already........ bad idea!!!!!!
  8. The Following 5 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    MB TD42 (26th June 2020), mudski (13th September 2018), PeeBee (13th September 2018), rusty_nail (13th September 2018), TPC (25th July 2020)
  9. #5
  10. The Following 7 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (19th June 2020), Arfa Brayne (18th May 2021), BrazilianY60 (5th February 2024), LMcasanova (25th July 2020), PeeBee (19th June 2020), Rossco (21st June 2020), Shalee (18th May 2021)
  11. #6
    193 Post(s)
    Yep, after slipping around on the smooth concrete floor with the plastic two step unit, I glued emery paper to the bottom of the feet - problem fixed, no more excursions at exactly the wrong time.
  12. #7
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    you can also just use a pencil and a bit of paper for that powerboard one, shade the back of it and the screw holes turn out darker on the paper, I did it the other day
    2008 CRD Auto Wagon
  13. The Following User Says Thank You to pollenface For This Useful Post:
  14. #8
    This is a whole new level of Coals On Top!!!!
    Wow! Upside Down! Pizza on the lid!!!!!!!!
  15. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    mudnut (23rd June 2020)
  16. #9
    193 Post(s)
    That is a clever idea, assume there is still a fair bit of heat from above and below, pizza should still be pretty moist as well as the steam has nowhere to get out.
  17. #10
    The Final definitive solution to front end shakes on a Nissan Patrol.
    Balance gents!!!
    It is so Obvious!!!
  18. The Following 6 Users Say Thank You to MudRunnerTD For This Useful Post:
    Cremulator (26th July 2020), MB (26th July 2020), mudnut (24th July 2020), NissanGQ4.2 (27th September 2020), PeeBee (24th July 2020), TPC (25th July 2020)
