Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Life Hacks 101
    330 Post(s)
    Ultimate Life Hack
  2. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (30th March 2021)
    109 Post(s)
    OK this might not be new to you but I just learnt a new trick and was amazed how great it works when rotating wheels/tyres. Remove wheel, shuffle replacement wheel/tyre into place, then instead of heaving the thing up in a crouched position, then trying to rotate it around so you get a stud through, and busting a pooper valve in the process, do this: Shuffle replacement wheel into place. Slide a spade/shovel under the outer edge of the bottom of the tyre. Push the spade/shovel handle down, thereby lifting the wheel up an inch or two to stud height. To rotate, slide the spade/shovel handle left or right to spin the wheel until studs line up with the holes. Push the wheel on. So bloody easy and takes no effort at all!
    Thanks to my old man I will use this trick from now on.
  5. The Following 10 Users Say Thank You to Plasnart For This Useful Post:
    BrazilianY60 (5th May 2021), Cremulator (31st March 2021), growler2058 (31st March 2021), Hodge (30th March 2021), MB (30th March 2021), mudnut (30th March 2021), MudRunnerTD (31st March 2021), PeeBee (30th March 2021), Stropp (3rd April 2021), Touses (31st March 2021)
  6. #13
    Expert Arfa Brayne's Avatar
    Jul 2016
    Good one Plas.
    Always done similar using the wheel brace or breaker bar under the tyre.
  7. The Following 2 Users Say Thank You to Arfa Brayne For This Useful Post:
    MB (18th May 2021), Plasnart (18th May 2021)
  8. #14
    Jul 2016
    When out bush with poor radio signal (am/fm), knock a tent peg into the ground and pour a billy of water over it.
    Hook a jump wire between the radio aerial base and the tent peg.
    Works brilliant most of the time.
  9. The Following 3 Users Say Thank You to Arfa Brayne For This Useful Post:
    MB (18th May 2021), MudRunnerTD (18th May 2021), Plasnart (18th May 2021)
  10. #15
    330 Post(s)
    Just saw this on Facebook..
    Nice little life hack.
    Jiggle a zip tie through that tough knot...
    This will give you loops and the knot should come apart simply.
  11. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    Cremulator (12th July 2021), growler2058 (12th July 2021), MB (12th July 2021), rusty_nail (12th July 2021)
