Results 1 to 10 of 10
Thread: Overheating 4.2 Diesel Y61
    Sep 2018
    Hello there
    My 2004 Y61 Patrol is overheating(4.2 Diesel). Water pump is new, fan clutch is new, radiator is clean, thermostat is working and it still overheats. I don't know what to do now, any recommendations?
    Thanks.
    472 Post(s)
    G’day mate, have read on here before some poor bugger scored a dud (failing) fan clutch from new. Can’t remember the exact home test sequence the team here kindly helped figure it out with him though.
  4. The Following User Says Thank You to MB For This Useful Post:
    ZuraKone (14th September 2018)
    By "Radiator clean" do you mean the Rad has been removed, the top and bottom tanks taken off and the core rodded or replaced?
    If not, thats where I would go next
    If it has only had a Rad flush that is usually not worth a pinch of pelican poo...
    Sep 2018
    Yes, That's what i mean
    581 Post(s)
    How hot is it getting?
    Do you have an aftermarket or just using the OEM gauge?
    Just getting hot towing or just on big hills or all round too hot even idling, etc?
    Anything in front of the radiator not from factory - Intercooler, winch, spot lights, LED Bars, bullbars that could be restricting airflow?
    Jan 2018
    Been there and one that.
    I dont trust Radiator cleaned..... For me. New radiator fixed the problem was it was "apparently cleaned"
    Also Thermostat. Take it out and drive around to test without it
    Sep 2018
    Water pump was out of condition 1-2 month ago, I fixed it and it was working perfectly(By the way i fixed fan clutch and cleaned radiator). Now it started overheat again, way more strongly. Little hill and overheat is starting. also, last 2 weeks, I was in mountain region and engine was little bit loaded, but was working fine nothing like overheat.
    Front end is stock(except codan radio antenna). Radiator, Intercooler, everything is from factory
  10. #8
    Sep 2018
    Quote Originally Posted by drgtr View Post
    I tried without thermostat, It still overheats
  11. #9
    No airlock in the motor...i know with the 4.2 in gq it payed to park up hill and fill with a cut ot coke bottle
  12. #10
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    check all the heater hoses, even the small ones near fire wall. that if it's losing water regards Alex
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
