13th October 2018, 08:35 PM
Battery Indicator
Hi All,
I have recently done an engine transplant with a mate.
I had a TD42 in a GQ with a manual box.
I purchased a 2002 GU ZD30 with an auto box, and proceeded to take out the auto and the ZD.
I put in the TD42 and a manual box and am now in the process of addressing the wiring.
One issue I have encountered which I didn't think I would, is that the battery indicator light is always on.
I have checked the alternator, and it is charging, the plug from the ZD loom fits fine.
I have yet to plug in an ODB-II reader, but will look to do that in the next few days, but in the mean time, does anyone have any pointers on what to look for?
I have the following working:
- RPM
- Fuel Solenoid
- Reverse lights
- Speed sensor
- Water Temp
I am yet to do:
- AC (plug fits, have not tested/troubleshooted it yet, have also heard that I need to earth a wire or it will shut off on over temp or something, any one know what this is?)
- Fuel sediment sensor (cant seem to find any thing about this in the Y61 manual(s), not sure if it is called something else)
- Engine Error light (No engine management on my TD42, so need to disable this light somehow)
If I need to provide more info to help troubleshoot, please let me know.
I have been using the following Y61 manuals
- Supplement III 3rd Revision (SM9E-Y61CG3)
- Supplement V 1st Revision (SM1E-Y61EG1)
Any help on the above much appreciated.
-Hurgh-
13th October 2018 08:35 PM
15th October 2018, 07:50 AM
Had a quick look through the GU and GQ service manuals I have here, and whilst I am in no way an electrical guru I have noticed that the ZD30 alternator appears to have two wires go to the battery whilst the TD42 one only has a singular wire heading that way?
TD42:
ZD30:
