Results 1 to 7 of 7
Thread: Hi wagon rear upper coil pads falling out
    Sep 2018
    queensland
    Hi I have a 08 gu wagon 2 inch lift.
    Crawling under the rear the other day I see the the upper spring pad is all deformed and not correctly seated.
    I’m assuming it’s caused by too much flex? And the pad car out abit.
    In any case I want to replace the upper pads now.
    How can I go about this on the drive way is there a way to do it we’re I don’t have to remove everything?
    Also how do I prevent this for happening on the cheap? I’m thinking something with zip ties lol.
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Quote Originally Posted by Fireblade View Post
    I just installed the Boss Coil Tower Brace and used a coil spring compressor, compress the coil enough and you sould be able to slip a new pad in easily. You will need to raise the body on car stands and remove the wheels to get the diff to drop far enough.
    Jack
    465 Post(s)
    I zip tied mine about three years ago. Still there now I think. Lol
    Sent from my crapPhone using Tapatalk
    Sep 2018
    queensland
    Where did you zip tie? The pad to the coil or the pad to the coil chassis mount
    Sep 2018
    queensland
    So I put net coil pads in, easy job. Zip ties the pad to the coil looks like my coils are stock not aftermarket wonder if that’s why they popped out?
    465 Post(s)
    Sorry man. Pads to coils...
    Sep 2018
    queensland
    all good mate, once i had them out common sense told me pad to coil.
    on closer inspection turns out the coils are efs branded, good to know.
    front pads are a bit stuffed to so ill do them soon enough.
