Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: No power to low beam
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Thanks again ET , will follow all that and see where I end up , car has taken a battering from the thousands of Kay's of corrigations and I'm still finding damage so it's not impossible something has shaken loose .
    Have not driven at night for over 3 months while away .
  2. The Following User Says Thank You to GQtdauto For This Useful Post:
    the evil twin (5th September 2018)
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Just as you said ET it was the contact point on the stalk ,and you're right was a stupid design so if I end up keeping it I will do as suggested and redo the wiring with relays ,thanks again for you're help .
  5. The Following User Says Thank You to GQtdauto For This Useful Post:
  6. #13
    80 Post(s)
    If you are going to use lugs to connect your wiring, use a good brand such as Wattmaster and spend some money on a pair of proper ratchet style crimpers, not those cheap pressed steel ones. Use heat shrink or liquid tape to seal the cables. I mounted all my relays in a waterproof Junction box.
    I also used auto circuit breakers, but I have no idea if they are better than fuses or not.
    http://www.nissanpatrol.com.au/forum...relays-on-a-GQ
  7. The Following User Says Thank You to mudnut For This Useful Post:
    GQtdauto (5th September 2018)
