2nd September 2018, 06:21 PM
Squeak after engine turned off
Hi Folks,
I have a 2012 3.0l diesel Patrol.
It makes a fairly loud squeaking noise after the engine is turned off.
Something like "eee-arrr". It makes this noise about 4 times after the engine is turned off.
Any ideas?
Thanks,
Kirk
2nd September 2018 06:21 PM
2nd September 2018, 06:56 PM
Just a thought... Could it be the EGR valve trying to close or open? It could be faulty or stuck.
They go to a default state when motor is shut down. I can't remember whether open or shut.
2nd September 2018, 08:02 PM
Thanks Hodge.
I forgot to mention that the noise goes on for several seconds after the engine is turned off. Sometimes it is still going after I've got out of the vehicle.
2nd September 2018, 09:06 PM
The only noise mine makes after turning off is the radio aerial retracting.
2nd September 2018, 09:41 PM
Could this be a small vacuum leak, equalising once the car is off and vacuum is not being generated - cracked hose?
3rd September 2018, 06:58 AM
Kirk
Thanks Hodge.
My crd used to do exactly the same.
Motor off get out of car and I can hear a small whirl and something attempting to close or open.
Usually went on for good 2-3 seconds unless engine was very cold.
It turned out to be the EGR valve replaced by Nissan. Walls around the butterfly flap inside the valve were caked in EGR gunk and flap wasn't closing properly.
But ... Could be something else.
4bye4 made a good point is it the aerial retracting and making a squeal...
3rd September 2018, 02:04 PM
The egr piping has a tendancey to split on the later models.
maybe block the egr with a special SS plate
GQtdauto (5th September 2018)
5th September 2018, 12:48 PM
I used a great diagnostic tool, the radio. I turned it off for a couple of days, and am faily sure I hear the same pitched sqeek when I put my foot on the clutch.
Thanks for the tip 4bye4.
I discovered that my aerial was indeed stuck so I loosened it up with some RP7. But I’m guessing my model doesn’t have a retractable aerial because it doesn’t move of its own accord.
Thanks PeeBee.
I hope you’re right. Better to replace a hose than some expensive other repair.
Thanks Hodge for the EGR valve info. Sounds like a possibility considering that the noise continues after the engine is off.
threedogs, are you suggesting the EGR isn't essential and I can just block it off?
The Following User Says Thank You to Kirk For This Useful Post:
4bye4 (5th September 2018)
5th September 2018, 02:07 PM
Kirk
The EGR is essential in earlier engine death. Other than that, they are not needed on any diesel engine. Just a legal requirement thats all...
20th September 2018, 06:31 PM
I took the vehicle to the mechanic, and it was indeed the EGR. Thanks everyone.
