Results 1 to 7 of 7
Thread: zd30 crd squealing noise
    Apr 2013
    Have done a search and taken the car in for a diagnosis which I got told is the manifold gasket (common issue) but another mate rekons it's the egr pipe leaking air (can feel it escaping when put hand under it). Basically makes a bit of a squeal on acceleration coming from the back of the engine on turbo side. Car still runs fine boosts fine etc. Only mods are egr block and 3 inch exhaust. Just want some more opinions as to which it's more likely to be, Mechanic I took it to knows his shit and I trust him just hate the thought of spending big dollars if it potentially won't fix my issue.
    .......... TPC's Avatar
    63 Post(s)
    Sounds like exhaust manifold gasket to me, it is common and studs often break when being removed. Probably need manifold machined too.
    Had mine done few weeks ago.
    175 Post(s)
    Cracked EGR pipe at back or motor between motor and firewall.
    Very common issue on crd zd30s.
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    My car was doing it at high boost. Some idiot didn’t tighten the pipe going into the intercooler did he. Geez I’m stupid
    461 Post(s)
    Second that. Dont even replace the pipe, just get a blanking plate off eBay to block off the exhaust side.
    175 Post(s)
    I went through hell pin pointing my squeal .
    Went through 20 different intake hoses and clamps the whole time I was so sure it was somewhere along the boost pathways ...
    But in the end it was a micro crack smack in the middle of the EGR pipe in the most c*** of spot singing it's annoying whistle when turbo spools up under load ...
    Apr 2013
    Yeah car has an egr blanking plate installed but obciously not on the exhaust side. Yes mine is doing that annoying whistle when under load as well. Sounds very much like it will be the egr pipe, will mention that when I get it fixed.
