Results 1 to 7 of 7
Thread: Oil blow
    Aug 2018
    COBAR NSW
    Oil blow
    Hi Fellas
    I just got home and was pulled up for 20 mins when I walked around to unload me Ute and noticed that I had oil all up under my Ute from the breather hose and a fair bit had dropped off on my drive way
    I had just drove 70klms
    I checked my oil and it was down about 1/3rd
    Filled it back up started it and
    My engine is ticking
    It’s a 2001 GU Ute
    4.2TD with bigger fuel pump
    Biggest cross country intercooler
    Biggest radiator
    Stainless snorkel
    4 inch intake
    And 3 inch exhaust
    Any ideas what I’ve done guys
    472 Post(s)
    Here’s hoping for you brother, terrible mechanic I’d be but fingers truly crossed it’s not from crankcase pressure, inner cylinders trying to get out :-(
  4. The Following User Says Thank You to MB For This Useful Post:
    STEVO83 (28th August 2018)
    Aug 2018
    COBAR NSW
    Thanks brother
    I’ve got em crossed
    I’ve read a couple other forums and I have changed oil and it’s a bit overdue for a service
    BUT I would think it would blow that much out
    I’m thinking it blew a litre or two out in 70klms
    I was punching it but only about
    130
    It will do 190klm
    It’s got 255hp at rear wheels
    472 Post(s)
    I’m lost Stevo mate, doesn’t sound too good :-(
    May 2016
    8 Post(s)
    mmmm you had 255hp !!!
    cross your legs to .. think you might have an expensive problem .
    piston or ring failure. oh shoot .
  8. The Following User Says Thank You to Tip12345 For This Useful Post:
    Rossco (29th August 2018)
  9. #6
    581 Post(s)
    Any update on this mate?
  10. #7
    Aug 2018
    COBAR NSW
    Oil blow
    Hi mate
    Havnt found for sure yet
    But mechanic seems to think it’s
    A turbo seal which is pressurising sump
    But I should know more this arvo
    Or tomorrow when I get home
    It’s still starting fine
    But is lacking a little power
    Took the oil cap of and doesn’t seem
    to Smokey, no more than usual anyway
    But I’ll let ya know for sure when I find out
    Cheers Stevo
