Results 1 to 10 of 15
Thread: Exhaust
    Aug 2018
    Exhaust
    Looking at getting a 3 inch straight through exhaust for a gu wagon td4.2t and a EGT fitted. What brand EGT to fit and roughly how much should the exhaust cost? Just a rough estimate is fine
    461 Post(s)
    Pipe will cost $600 - maybe $1400 for a top level stainless system. As for gauge, thats a tricky one. Just dont buy cheap. VDO, McNally and Redarc are the first three that come to mind.
    Aug 2018
    Alright sounds awesome, thanks heaps for the EGT info I’ll look into those brands 👌
    472 Post(s)
    As Mudski and others have kindly suggested, VDO & McNally are probably no doubt the ducks performance nuts! Redarc 3in1’s with their audible alarm for EGT Mrs MB settings are hopefully foolproof.
    https://www.redarc.com.au/egt-boost-...rature-display
    “Multiple programmable alert levels with amber or red backlight and audible beep”
    I like the autometer gauges a lot.
    175 Post(s)
    I have the Beaudesert 3" from turbo to the arse-end and the Redarc gauges. Cost a bit all up but it's a quality setup i like to think.
    194 Post(s)
    Just my 2c comment, based on numerous encounters and use of temp control instruments in industry, the important points are, regardless of who makes the items are 1) the thermocouple, the bit that sticks into the exhaust pipe, needs to be accurately calibrated against a range of known temps. A calibration certificate for that probe will ensure its accuracy; 2) the gauge and probe need to be individually matched or trimmed to the calibrated temps - a certificate of this that will ensure accurate indication. Matching of the indicated temp against a standard ensure accuracy, and is typically achieved using a trim pot or puk inside the gauge.; 3) don't mix and match makes or styles of gauges and thermocouples. Its likely the manufacturer works to a generic bulk calibration standard and simply matches the gauges to the standardised thermocouple - at the least this would give a degree of accuracy and repeatability, however does not really guarantee temperatures are what is indicated.
    An instrumentation tech would use whats called a 'hotbox' that generates a known temperature as a standard and the EGT probe output is compared to the standard. the tech would then trim the trimpot in the gauge to match the calibrated temp. Depends on how accurate you want. I doubt that a variance of 10-20 deg would make any difference in the real world for the type of use the EGT is engaged
  9. #8
    Aug 2018
    Ok lads so am I best of ordering my exhaust beau or red back? Then putting it in back of wagon with EGT to take to exhaust shop to be fitted? Also I hear dump pipe makes a massive difference so what dump pipe to order with it? My patrol has standard turbo
  10. #9
    Sep 2018
    queensland
    3 Post(s)
    any thoughts on
    https://www.ebay.com.au/itm/PERFORMA...gAAOSwpINZYcWg
    brand is Autotecnica, ships from victoria. looks good hard to spend $500 on a redarc
  11. #10
    Aug 2018
    Link doesn’t work for me mate
