Results 1 to 6 of 6
Thread: Transmission breather questions
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    I was about to do the usual thing and extend the transmission breathers to the top of the firewall. However after checking out the existing vents for the front three, I just wonder if it is much of an advantage to do these. Mine are already 1 metre above ground and fairly well protected (well up inside the left front wheel cavity area) and relocating would only gain a few inches. Opinions?
    The rear diff is a different matter and that one could definitely do with relocating.
    Also, if it is worthwhile relocating, why replace the fittings on top of the gearbox, front diff, transfer case? It is not an easy task to replace the existing fittings. There is a very convenient place to break into the existing tubes where there is a rubber hose linking two sections of metal pipe in the engine bay just behind the shocky hump which would only require a short run of hose to get up the firewall.transvent.jpgIt is not an easy task to replace the existing fittings so why do it? Is there some useful difference between the original and the replacement (except for the connection for the 1/4 inch polyurethane hose all the kits seem to use)?
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    I've extended all the breathers and added a cheap filter facing downwards so that there is bugger all chance of water getting into them. A lot of kits are mounted with the buds facing upwards which IMHO defeats their purpose.
  4. The Following User Says Thank You to mudnut For This Useful Post:
    Brissieboy (16th August 2018)
  5. #3
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Yep. I had intended doing something similar - if I do extend.
    BUT...this lowers the breather hole below the maximum possible - to about the same as the factory fitted level. So why bother? Trying to figure out if it actually beneficial to extend/relocate the front breathers, and why.
  6. #4
    The master farter
    mudski's Avatar
    461 Post(s)
    I haven't bothered doing the transfer and transmission breather because they are already mounted in a good spot from factory.
  7. The Following User Says Thank You to mudski For This Useful Post:
    Brissieboy (20th August 2018)
  8. #5
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Thanks mudski, that was my thoughts as well. I will stick with these.
    So, is there anything special about the kit supplied fittings that replace the originals on the diffs/gearboxes?
  9. #6
    The master farter
    mudski's Avatar
    461 Post(s)
    Quote Originally Posted by Brissieboy View Post
    No, should all just screw in and then run the hoses up into the engine bay.
  10. The Following User Says Thank You to mudski For This Useful Post:
