Results 1 to 8 of 8
Thread: Are these external Storage Solutions like extended range fuel tanks, Bladders Safe?
    May 2017
    Gold Coast
    Question Are these external Storage Solutions like extended range fuel tanks, Bladders Safe?
    I am thinking to purchase an extended range fuel tank but is worrying whether it is safe container for flammable Fluids or not...
    Quote Originally Posted by rickycook View Post
    Absolutely. Long Range Tanks have to meet strict Engineering and ADR Compliance. I have a 147lt LRA Tank in teh back of both my Patrols. The GQ has landed HARD onto the tank and it must have a 20lt dent in it. The GUIV has a 10lt dent in it, not trying hard enough.....
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (13th August 2018)
    472 Post(s)
    Slightly off track and I do believe it is illegal to carry ‘petrol’ jerry cans on rear wheel/bumper carriers but is it also same for ‘diesel’ assuming so but keen to learn?
    194 Post(s)
    Looking at the original question, 'bladders' were also asked about. I think there are plenty of 'fit for purpose' bladders in use in the military for fuel use, however unsure if any are actually ADR approved for use in the civilian environs. I would think they are a tray installation requiring a fair attention to detail around material puncture protection. I have not seen one in use. I think you would simply need to ask about local compliance and also fitting requirements. Are you thinking of installing it inside the cabin for example and if thats allowable - suggest maybe not. Any of the commercially made brand tanks are fit for purpose and compliant I would think.
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Also have a look at the newish poly tanks. Tough little buggers and light compared to steel.
    Arb frontier is just one brand
    https://youtu.be/CIkCCnfLdzg
    ________________________
    ______ 2017 D-Max _______
  8. The Following User Says Thank You to Maxhead For This Useful Post:
    mudnut (14th August 2018)
  9. #6
    Handy linky thingy for ya mate... http://rveethereyet.com/it-is-illega...ack-of-my-van/
    It has the 'go to' references for each state and in a nutshell...
    Also this 'un isn't bad http://www.withoutahitch.com.au/trav...ng-flammables/
    Diesel OK in approved container/s.
    Petrol OK but max of 250 litres total on/in vehicle including all tanks and approved container/s.
    LPG No (indeed latest regs say for new build camper trailers and vans the LPG must now be inside the A frame if carried 'externally'.
  10. The Following User Says Thank You to the evil twin For This Useful Post:
    MB (14th August 2018)
  11. #7
    472 Post(s)
    Cheers ET, great links mate!
    The second ones got me a bit confused though with: “If they’re mounted on the rear of your car, you must be an approved, ADR compliant carrier”
    Thinking they’ve done a typo booboo there?
  12. #8
    yeah, typo methinks...
