Results 1 to 10 of 12
Thread: Using a TD42ti pump in a GQ (wiring question)
    Dec 2012
    Work
    I have just fitted an 06 TD42ti motor into my GQ and just curious if anyone has a work around for the TCV on the pump and tacho sensor?
    I don’t have the factory ECU, using a GQ loom, have read about using a Hobbs switch to “trick” the TCV and using a spacer on a GQ tacho sensor but can’t find any real information about either.
    I will eventually be replacing the pump with a full mechanical pump but not flush with cash either so looking for a temporary work around, thanks in advance....
    Just another Blue over Silver GQ with another TD conversion
    581 Post(s)
    I can't help with the pump but yep I had to put a spacer on the sensor and it worked fine.
    Below 800rpm though the needle flutters a bit.
  4. The Following User Says Thank You to AB For This Useful Post:
    Reddave (13th August 2018)
    581 Post(s)
    I got the spacer from Patrolapart mate, let us know if you want more info mate, thickness, etc.
  6. The Following User Says Thank You to AB For This Useful Post:
  7. #4
    Dec 2012
    Work
    Thanks, I’ll call patrolapart in the morning!
  8. #5
    Dec 2012
    Work
    Called patrolapart this morning, they don’t have the spacers so I made my own!
    Now have a working tacho, just need to sort out the TCV wiring now
  9. The Following User Says Thank You to Reddave For This Useful Post:
    AB (14th August 2018)
  10. #6
    581 Post(s)
    Nice one!
    Does yours flutter or drop under 1000rpm?
  11. #7
    Dec 2012
    Work
    Sits fine, will see what it does when I can actually drive it, which will be in a few days
  12. #8
    Sep 2014
    Hey Reddave,
    how did you go with the Ti pump and the hobbs switch.
    I'm trying to put the Ti pump onto my silvertop.
    Dec 2012
    Work
    Got it all sorted, but will be coming off soon to put a bigger pump in.
    Let me know what you’re stuck on and I’ll try help out
  14. #10
    Jan 2020
    Hey mate digging up the past
    [QUOTE=Reddave;783161]Got it all sorted, but will be coming off soon to put a bigger pump in.
    How did you get this sorted mate i cant stop mine rattling it's head off and missing at idle
