Results 1 to 3 of 3
Thread: Oil catch tank
    Beginner Semiao's Avatar
    Jun 2018
    Portugal
    Oil catch tank
    has anyone installed a OIL CATCH TANK on a RD28?
    i was told that it will save the engine in a long run from failing but i´ve havent seen any one on this installed yet, please help and if you guys have photos of it it would be even better!
    thank you in advance!!
    194 Post(s)
    Yes, I had one on a 1997 RD28T engine, worked well. Simple to install, but you need to consider what you do with the captured oil, either vent it to atmosphere constantly with a drain line or store it in the catch can or the drain line. Mine was constantly vented to atmosphere and unfortunately the hose was not long enough and made a black oily mess on the chassis rails until i installed a small stop valve then dropped the oil periodically.
    I used one like this
    https://www.ebay.com.au/itm/ProVent-...catch+can.TRS0
    It comes with instructions of how/where to fit. Unfortunately I do not have any photos for you as the engine was replaced.
    Jun 2018
    Portugal
    thanks for the information, it helps a lot for the installation.
    i have a different tank but the function is the same
