4th August 2018, 10:25 PM
Oil catch tank
has anyone installed a OIL CATCH TANK on a RD28?
i was told that it will save the engine in a long run from failing but i´ve havent seen any one on this installed yet, please help and if you guys have photos of it it would be even better!
thank you in advance!!
4th August 2018 10:25 PM
4th August 2018, 10:33 PM
Yes, I had one on a 1997 RD28T engine, worked well. Simple to install, but you need to consider what you do with the captured oil, either vent it to atmosphere constantly with a drain line or store it in the catch can or the drain line. Mine was constantly vented to atmosphere and unfortunately the hose was not long enough and made a black oily mess on the chassis rails until i installed a small stop valve then dropped the oil periodically.
I used one like this
https://www.ebay.com.au/itm/ProVent-...catch+can.TRS0
It comes with instructions of how/where to fit. Unfortunately I do not have any photos for you as the engine was replaced.
4th August 2018, 11:14 PM
thanks for the information, it helps a lot for the installation.
i have a different tank but the function is the same
