Results 1 to 8 of 8
Thread: Proportioning valve alternative
    Apr 2018
    After having issue with a stuck proportioning valve on my GQ trayback, stripping it down and seeing the corrosion inside meant it needed replacing I set off looking. I was horrified to see aftermarket ones between $600 to $800 and genuine Nissan up to $1600 dollars I set off to find an alternative. Turns out the valve on the Mitsubishi Pickup Triton 86-07 is identical and a fraction of the cost. The stripped body is from the nissan original and the new one the Mitsubishi aftermarket one which cost 80 dollars delivered.
  2. The Following 15 Users Say Thank You to PKF For This Useful Post:
    @GUte (25th November 2023), BrazilianY60 (7th July 2023), Clunk (1st August 2018), Deano2506 (31st July 2018), gaddy (31st July 2018), graeme1969 (31st July 2018), jack (31st July 2018), MB (31st July 2018), mudnut (31st July 2018), mudski (31st July 2018), PeeBee (31st July 2018), taslucas (21st September 2023), the evil twin (31st July 2018), Touses (1st August 2018), Winnie (31st July 2018)
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Good find, well done.
    Jack
    Excellent find mate, think you'll make a lot of people happy with that one.
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    Good work mate
    462 Post(s)
    Shittot mate! Can you tell us where you bought it from too? And part number.
    Apr 2018
    Ebay... was cheap enough to take a punt. Checked it was for disc/drum and had the 3 lines. All good.prop valve.JPG
    Apr 2021
    Brazil
    Thank you very much for the tip. This helped me much in my GQ restoration in the absence of actual Patrol parts.
  10. #8
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    That is awesome work mate, great job, thanks for your information. Does anyone know if they're the same as GU units?
    Hello from Under Down Under!
