Results 1 to 6 of 6
Thread: Rattle at the rear
    May 2018
    Rattle at the rear
    Gday guys,
    Im 18 and i happily own a 2008 3.0L patrol. Recently i have noticed an annoying rattle to the back left of the vehicle when moving, but only if im in low revs (Eg - 1000 revs in 2nd or 3rd gear). The rattle is very loud and i have to push the clutch in a little bit to stop it or get up the an appropriate speed / rev level.
    I have had look to see if anything was loose but i couldnt find anything that could possibly make the noise..
    If anyone has an idea or can relate to this id love to hear what you have to say.
    Cheers guys
    Mark
    330 Post(s)
    Quote Originally Posted by MarkNelson99 View Post
    Gday guys,
    Cheers guys
    Mark
    Hi mate,
    It will likely be the end of the exhaust pipe rattling against the tie down point. drives me bonkers a bit. You can try and pull it away or use some Tie Wire and tie the bloody thing hard onto the chassis so it cant rattle.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Clunk (27th July 2018)
  5. #3
    more than likely what he said.
  6. #4
    May 2018
    Cheers boys, ill give it a look over the weekend
  7. #5
    Jan 2018
    Pt Augusta SA
    At eighteen I thought you would be too old for a rattle But yep exhaust rattle is the likely problem
  8. #6
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Fixed mine with a 1/2" garden hose (25mm long or whatever), split down one wall, slip it on the hanger rod to push across and secure it with a worm drive hose clamp. Needed it with 3" exhaust tail pipe.
