19th July 2018, 02:19 PM
Gearbox oil
Hi all
I am looking to change the gear oil on my GQ TD42.
Which oil have you guys found works best, and how much of it will I need to do Gearbox and Transfer case?
19th July 2018 02:19 PM
19th July 2018, 05:25 PM
for gearbox i'd go with a GL 4 grade over a GL 5, i think its 80-90.
transfer i think is 80-90 gl5
i'm using nulon as was the only gl4 i could get easily
The Following User Says Thank You to garett For This Useful Post:
JackoGQYoot (19th July 2018)
20th July 2018, 06:25 PM
always ran castrol vmx-m with a tube of nulon g70 in my gq, was the only oil i tried that made it shift any good
gone to the dark side 2017 vdj 79 dc
The Following 2 Users Say Thank You to billyj For This Useful Post:
MB (20th July 2018), mudski (24th July 2018)
20th July 2018, 09:51 PM
Blokes at our nearest Semi-Rural ‘Burson’s’ also swear by them Nulon tubes too BillyJ mate!
They reckon its the only stuff that gets their Land Crab boxes shifting without hassle. Did buy a tube once too and might give it to a close work mates GU having highway 5th <>4th issues and see what may prove too!
21st July 2018, 10:07 AM
Just found out I will need 3.9L for the gearbox and 2.2 for the transfer. Do you guys reckon I go for the full synthetic oil from penrite or the mineral from castrol? I've been told that a 4L from Penrite will be 62$ and I will need 2 of these. It seems pretty expensive but I am leaning towards full synthetic.
Td42 coily
21st July 2018, 11:38 AM
im normally a penrite man but the castrol vmx-m was the only oil that got the old girl shifting any good
22nd July 2018, 06:45 AM
I've been using the Pro Gear 75w-85 from penrite for years.
What ever you choose, it must be a GL-4.
GL-5 jams the syncros in a GQ manual transmission.
22nd July 2018, 05:12 PM
23rd July 2018, 07:20 PM
Cheers for the replies. Ended up going for Penrite GL4 as it worked out cheaper anyway.
23rd July 2018, 08:07 PM
Smart like tractor
Castrol VMX is the only oil I've used to make it cold shift properly. No need for an extra additive as it is already in the oil
96 GQ coil/Cab
08 G6eT
