Results 1 to 10 of 11
Thread: 2004 Dual Cab zd30di auto reverse lights on
    Apr 2017
    Hey all just got a quick confused question as soon as I put my Lights on my reverse lights are on BUT main twist is now while driving lights off and then when I put lights on car drops a gear turn lights off car goes up a gear even tested it with cruise control and freaked me out. Anyone got suggestions or ideas please guys
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    Don’t quote me but it sounds like a bad earth
    Legendary happygu's Avatar
    Sounds like a wiring issue ....
    It the Driving Light Switch linked in with the Highbeam, so that you cannot turn the driving lights on without highbeam being engaged too?
    Where is the power feed for the driving lights picked up from - I would disconnect and re-connect straight from a fuse off the battery
    Apr 2017
    Nah I can turn on Parker’s driving lights n high beam one at a time no worries there
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I recon Yeti's Beast is on the money with earth problem. It may be that the lights are partially earthing back through the gearbox ECU giving an indication that it should change gear. I dont know anything about how to rest it but someone here may. Is @Yendor still here? he may know.
    Quote Originally Posted by 4bye4 View Post
    snip... Is @Yendor still here? he may know.
    Nah, Rodney isn't here ATM, he got wacked with the ban stick.
    FWIW I agree with you guys and I would be checking LH tail light earth (and also trailer plug if fitted)... unless OP has aftermarket mods IE extra reversing lamps in which case I would disco them and see if the prob is still there
    461 Post(s)
    And I didn't even notice he wasn't here anymore. And its been nearly 12 months. Lol. Its a big rock I have here....
    ROFL... I miss him, he was one clued up fella for the elecktrickery thats for sure
  10. #9
    461 Post(s)
    Yes that he was for sure.
  11. #10
    Apr 2017
    Checked the lights-wiring-plugs-trailer plug and connectors cleaned them all up still the same. Attacked few earths before it got dark and no luck so far will definitely keep going and checking rest of earths. Thanks guys
