Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Hand Throttle
    472 Post(s)
    As Evil Twin mentioned above, old Rovers and their Capstan Winches also required outa cab RPM too was once also told from our old bloke similar to this IIRC: https://youtu.be/G-hYHMUncxY
    PeeBee (20th July 2018)
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Basically theyre a remnant from pre ecu vehicles.
    My ECU GQ had it
  5. #23
    472 Post(s)
    Personally speaking here I don't use it all!
    Rock climbing, get better accessories and learn how to climb.
    Agreed mate, get a 6.5NA with reduction gears and leave it on 550rpm idle for 1/2hr to catchup on ones morning stroll :-)
  6. #24
    Dec 2015
    WA
    5 Post(s)
    When I was installing the cruise control in the old GU2 I contemplated using the engine RPM signal instead of the tail shaft RPM, that way you could set RPM & have the safety of brake cutout. Would still work as cruise control in fourth or fifth, but could also be crawl control in low gears.
    Graham
  7. #25
    581 Post(s)
    Actually I tell a lie!
    Have used it on extreme cold snow trips for early morning trying to reach operating temp whilst finishing packing up camp.
