3rd July 2018, 12:25 PM
No aircon or sub fuel power
Hi, I have a 2006 GU Patrol wagon with ZD30 motor. I have a problem with fuses blowing on my aircon and sub fuel switch. We have tried disconnecting the module to the sub fuel tank in passenger side kick panel and disconnecting the wires to the switches. It still blows fuse. I suspect a wire issue so I need a good wiring diagram to check this out. Can any one help me.
3rd July 2018 12:25 PM
3rd July 2018, 04:53 PM
Moderator
Hi mate rhebsub tank pump is easily accessable under the car. Disconnext the wores and see if your still blowing fuses. Multimeter will test continuity there too
Check out my Toy -->
Rogue Dung Beetle
Steve hunt (4th July 2018)
4th July 2018, 04:38 PM
Thanks for the reply. I have done that already and fuses still blow. I suspect a wire short somewhere under the dash. That's why I am after wiring diagrams so I can trace wires etc.
4th July 2018, 05:31 PM
I am he, fear me
