Page 13 of 13 FirstFirst ... 3111213
Results 121 to 125 of 125
Thread: Best place to buy Warn Hi mount parts?
  1. #121
    330 Post(s)
    No point rebuilding.
    Buy the whole thing soon.
    FEATURES AND BENEFITS:
    High-output 6 HP motor for 10,000 lb.(4536 kg) pulling capacity and competition-level line speed
    IP68 waterproof and submersible Albright electrical contactor controls
    150ft of 3/8” (46m of 9.5mm) diameter Spydura® synthetic rope
    High-strength polymer control pack housing with throwback WARN® hublock logo
    Forged and polished 6061-T6 billet aluminum hawse fairlead for total corrosion resistance
    Newly designed stainless steel clutch knob
    Commemorative stainless steel drum end plate
    Two Oilite® bushings installed on pinion gear assembly for improved wear resistance
    Bolt-and-washer secures brake shaft delivers enhanced durability
    Winch is individually numbered with special edition labels
    Limited to 999 units worldwide
    Made in the USA
    Special Part Number Assignment: PN 101070: 10K lb pulling capacity, 10 improvements, Warn 70th anniversary release
    https://www.usoffroad.us/store/winch...versary-winch/
  2. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (13th October 2018)
    472 Post(s)
    No waffle there mate, specs sound great, must have a thinner core spool too by the sounds of it!
  5. #123
    The master farter
    mudski's Avatar
    462 Post(s)
    Just an update on this build. I sent of the drum and lower housing and end plate to a guy near by who apparently is the guru for Warn winches, Leslie SG and Sons. He rebuilds winches and mods brand new High mounts for competition ready. After talking with this guy for about an hour and seeing some of his work, I cam to a conclusion that this guys knows his shit. He had winches everywhere that people send to him to rebuild.
    So I took in my drum and lower housing and end plate for him to weld up the braces and install a bearing in the end plate.
    I ended up with a fully modded drum. 3mm thicker side plates on the drum with machined edges so they don't slice into the rope, the drum is smaller now I can fit 40m on rope and there is a groove in the end of the drum with an o ring fitted to ensure extra protection against water ingress. Plus a drian port added to the housing.
    All I need to do is add a fill port to the top housing and breather.
    So after I drill and tap for the fill port, its just about time to put it back together.
  6. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Hodge (12th March 2019), MB (11th March 2019)
  7. #124
    330 Post(s)
    Nice one Mark. What did the drum mods cost you. Did you ask Mal to drill and tap your brake shaft or did you buy a gigglepin one?
  8. #125
    The master farter
    mudski's Avatar
    462 Post(s)
    I have the GP brake shaft so no drilling and tapping required. It was $800 for all the work done. More than I anticipated but atleast its done, and properly.
  9. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (12th March 2019), MudRunnerTD (12th March 2019)
