Results 1 to 4 of 4
Thread: Alternator problem - weird behavior
    Jun 2018
    Nairobi, Kenya
    Hi, I recently bought a 1999 GU Patrol. Originally an RD28, it had an engine transplant to the TD42 naturally aspirated.
    The problem I have is I have to press down on the connector behind the alternator whenever the vehicle is started for it to charge.
    I have tried to clean the contacts, press the connector tighter but still no difference. Once I press on it, the alternator charges normally until next start up.
    Any ideas why and a solution please?
    175 Post(s)
    Possibly annealed cable at the lug? Try pulling cable out, cut and re-crimp then connect.
    Legendary happygu's Avatar
    or Dry / Cracked Solder Joint in the alternator plug
  5. The Following User Says Thank You to happygu For This Useful Post:
    Hodge (27th June 2018)
    Gold Coast
    It is all too easy to turn the connection bolt when removing/fitting the cable and that can/will cause issues inside the alternator.
    However it sounds like the issue is in the external connection (as Hodge and happy gu said)
  7. The Following User Says Thank You to Dr Gary For This Useful Post:
