Results 1 to 6 of 6
Thread: Td42 turbo squealing noise
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    G'day all,ive got a td42 with dts turbo kit.
    Kits been on for about 1 year,motors done 205,000ks.
    Last couple of days she's making a squealing noise as boost comes on.
    Seems to be when cold but only does it if i put my boot into it hard in 1st and 2nd gear.
    It's still getting full boost...15psi and still goes really well.
    I'm thinking maybe it's ex manifold gasket?
    Anyone else had this prob or know what it could be?
    Cheers!
    581 Post(s)
    Yep could be gasket or warped manifold.
    Do you have a top mount IC?
    Very common for an intercooler to have a little crack and the harmonics of the turbo come out and close up a bit when heated up, etc.
    Apr 2017
    Hobart,tasmania
    Gday ab.
    No i/c as yet,tassie winters don't really require one.lol
    Think I'll get the torch out and look for soot around the manifold.
    Would cross over pipe to inlet manifold leak make the same noise?
    She's got a bit of oil mist around there
  5. The Following User Says Thank You to Deano2506 For This Useful Post:
    AB (19th June 2018)
    581 Post(s)
    It could I guess but the sound wouldn't go away when it's warm.
    Just confirming sound goes when reached operating temp yes?
    581 Post(s)
    Unless you have a crack in the cross over which is unheard of but you could check that easy.
    Apr 2017
    Hobart,tasmania
    Yes goes away when warm,only been driving to work and back max speed 60ks
    I'll get her out on the highway and see what happens
