Results 1 to 3 of 3
Thread: Boost pressure setting.
    Patrol Guru Coldcomfort's Avatar
    Sep 2012
    Yea, Victoria
    2 Post(s)
    Hi all, what is the go with setting the over boost alarm on the redarc boost gauge? What has everyone done?? Whats the alarm level set at? Its a stock 2012 CR 3.0.
    Cheers all.
    Be the person that your dog thinks you are!!
    Ballarat, Vic
    174 Post(s)
    I suspect it has to do with individuals tolerance of risk levels.
    Can't help with the CR3.0, but expect there will be someone along soon who can advise
    I was advised that 550-600deg.C was the 'back off point' for my TD42i. Occasional quick squirts above that may be OK, but not sustained use.
    As it is I am cautious & set my redarc alarm at 525 deg.C ...... but realistically rarely reach that sort of temperature. Most of the time I'm between 250 & 450.
    Oops I somehow read EGT when you actually wrote boost .... how does that happen? Haven't bothered setting a boost alarm on mine, it maxs out at 13.5psi (up from the stock 7) - running standard crimped intercooler.
    A Nomadic Life (Blog)
  4. The Following User Says Thank You to Cuppa For This Useful Post:
    Coldcomfort (17th June 2018)
  5. #3
    SUCH IS LIFE Maxhead's Avatar
    ACT
    On my 2012 I had the alarm set at 20, I never really seen it go over 17psi.
    The only time the alarm went off was when I blocked the egr, very quickly I took that off
    ________________________
    ______ 2017 D-Max _______
  6. The Following User Says Thank You to Maxhead For This Useful Post:
