Results 1 to 2 of 2
Thread: 99 GU TB45 Dual Fuel
    Jun 2018
    Port Macquarie
    Hi all, really hoping for some advice.
    I recently purchased a 1999 GU Patrol TB45 on dual duel and am having an issue with smoke on startup.
    Whilst warm and driving the patrol doesn't blow smoke but when starting up or cold it blows A LOT of white smoke and a decent amount of water from the exhaust, for about 40 seconds to a minute.
    Has anyone had this issue or have any advice? would be greatly appreciated.
    Jun 2018
    Petrol Engine In the cold weather the white smoke can be quite normal. If you have any faulty in engine coolant or engine overheating might be from these reasons:
    *A cracked or warped cylinder head.
    *Head gasket failure
    *Cracked engine block
    Another reason for Petrol Engine Faulty fuel injection system Incomplete air/fuel mixture
    • Incorrect fuel injection and valve timing
    • Faulty fuel pump and/or injection pump
    Diesel Engine In cold weather may be unburned fuel or coolant going through the engine. But mostly, it is the incorrect injector timing in the cylinders
    Leaking coolant or water dripping into combustion chamber water
    • Bad head gasket
    • Cracked block or cylinder head
